Knowledge Base Article
Why is there a significant link up delay difference between Serial Lite III Streaming Intel® FPGA IP instances in simulation?
Description
Due to the reset staggering feature of the Intel® Stratix® 10 L-Tile transceivers and H-Tile transceivers, you may observe significant link up delay difference between Serial Lite III Streaming Intel® FPGA IP instances in simulation.
Resolution
To work around this effect in simulation, change the following in the <ip instance phy top>.v under the sim folder:
    From
        .reduced_reset_sim_time          (0),
    To
        .reduced_reset_sim_time          (1),
An example of the <ip instance phy top> .v file is shown below:
        altera_sl3_tx\altera_sl3_phy_top_181\sim\altera_sl3_tx_altera_sl3_phy_top_181_jl2kkei.v
#Note that this modification reduces the link up time in simulation only.
This is the expected behaviour and will not be changed in any future release of the Intel® Quartus® Prime software.
Updated 11 months ago
Version 3.0
