Knowledge Base Article
Why is there a 1-bit error in the Intel® Stratix® 10 H-Tile Eye Viewer when DFE is enabled?
Description
Due to a problem with the error counter inside the Intel® Stratix® 10 H-Tile Eye Viewer, it may report an incorrect 1-bit error when the DFE is enabled.
Resolution
If you are using the transceiver toolkit in Intel® Quartus® Prime Pro Edition Software version 17.1, it will perform automatic correction for the incorrect error count.
If you are reading the error count value through the Avalon-MM interface with DFE enabled, you should manually subtract the reported error count value by 1 when the reported error count is greater than 0.
Updated 3 months ago
Version 2.0
