Knowledge Base Article
Why is the Worst-Case MTBF not calculated for the nodes {*|soft_logics|rst_ctrl|pld_clk_ninit_done_sync_inst|din_s1}?
Description
Due to a problem with the Quartus® Prime Pro Edition software version 25.1 and earlier, the "Worst-Case MTBF" is not calculated for the nodes {*|soft_logics|rst_ctrl|pld_clk_ninit_done_sync_inst|din_s1} and results in "n/a (no valid slack)" by Timing Analyzer. This problem affects all designs containing the P-Tile PCIe FPGA IP.
Resolution
A patch is available to fix this problem in the Quartus® Prime Pro Edition software version 25.1. Download and install patch 0.06 from the following links:
- Download patch 0.06 for Windows (quartus-25.1-0.06-windows.exe)
- Download patch 0.06 for Linux (quartus-25.1-0.06-linux.run)
- Download the Readme for patch 0.06 (quartus-25.1-0.06-readme.txt)
A patch is available to fix this problem in the Quartus® Prime Pro Edition software version 24.3.1. Download and install patch 1.21 from the following links:
- Download patch 1.21 for Windows (quartus-24.3.1-1.21-windows.exe)
- Download patch 1.21 for Linux (quartus-24.3.1-1.21-linux.run)
- Download the Readme for patch 1.21 (quartus-24.3.1-1.21-readme.txt)
The problem has been fixed starting with Quartus® Prime Pro Edition software version 25.1.
Updated 5 months ago
Version 5.0No CommentsBe the first to comment
