Knowledge Base Article
Why is the timestamp accuracy error of PTP designs with the 25G Ethernet Intel® Stratix® 10 FPGA IP higher than expected?
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition Software Version 22.4, PTP designs using the 25G Ethernet Intel® Stratix® 10 FPGA IP may observe higher timestamp accuracy error values in both simulation and hardware.
This problem will impact 10G and 25G rates.
Resolution
To work around this problem in the Intel® Quartus® Prime Pro Edition Software v22.4, compensate the timestamp accuracy error by adding the following value on top of the configured RX PMA latency value in the CSR register 0xB06 (RX_PTP_PMA_LATENCY):
- 25G mode: Add 2.56ns (one clk_rxmac clock cycle)
- 10G mode: Add 6.4ns (one clk_rxmac clock cycle)
This problem has been fixed in version 23.1 of the Intel® Quartus® Prime Pro Edition Software.
Updated 11 months ago
Version 3.0
