Knowledge Base Article
Why is the system PLL incorrectly instantiated for F-tile Ethernet Hard IP 400G-4 FHT design examples with Auto-Negotiation and Link Training (AN/LT) enabled?
Description
Due to a problem in the Quartus® Prime Pro Edition software version 25.1, you may see an incorrect system PLL instantiated when using the Dual 400G-4 FHT Design Example for F-tile Ethernet Hard IP with Auto-Negotiation and Link Training (AN/LT) enabled designs.
Resolution
For a workaround for this problem, follow the steps below:
Open the “eth_f_hw.v” file and update the lines below
1)    Add the below line:
wire [INSTANCE_NUM-1:0] o_refclk_out;
2)    In the systemclk_f_0 section, update the commands below:
systemclk_f_0 sys_pll(
        //.out_systempll_synthlock_0(),
        .out_systempll_clock_0(i_clk_sys[portid2]),
        //.out_refclk_fgt_1(),
        .in_refclk_fgt_1(i_refclk2pll[portid2]),
        .in_refclk_fht_0(i_bk_refclk2pll[portid2]),
        .out_fht_cmmpll_clk_0(i_clk_ref[portid2]),
        .out)coreclk_1 (o_refclk_out[portid2])
See below highlighted lines below for reference
This problem is fixed beginning with the Quartus Prime Pro Edition software version 25.3.
Updated 4 months ago
Version 4.0
