Knowledge Base Article
Why is the Slot Clock Configuration parameter invisible when the PCIe0/PCIe1 Port Mode parameter is set to Native Endpoint in the GTS AXI Streaming FPGA IP for PCI Express*?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 25.1, you might notice that the Slot Clock Configuration parameter is invisible when the PCIe0/ PCIe1 Port Mode parameter is set to Native Endpoint.
Resolution
To work around this problem in the Quartus® Prime Pro Edition Software version 25.1, follow the steps below.
1. To set the parameter to True:
i. Open the GTS AXI Streaming FPGA IP for PCI Express and set the Port Mode to Native Endpoint.
ii. Go to File and click "Save".
iii. Click "Generate HDL…" and then click on "Done".
2. To set the parameter to False.
i. Open the GTS AXI Streaming FPGA IP for PCI Express* and set the Port Mode to Root Port.
ii. Go to PCIe0 -> PCIe0 Settings -> PCIe0 PCI Express / PCI Capabilities -> PCIe0 Link tab to uncheck the Slot Clock Configuration parameter.
iii. Go to File and click "Save".
iv. Click "Generate HDL…" and then click on "Done".
v. Open the IP in the IP Parameter Editor in the Quartus® project to set the Port Mode to Native Endpoint.
vi. Repeat Step iii and iv.
The problem has been fixed starting with Quartus® Prime Pro Edition software version 25.3.
Updated 4 months ago
Version 4.0
