Knowledge Base Article
Why is the simulation failing with a timeout error when running 1x10.3125G RSFEC Direct Mode (System PLL Clocking) Example Design of the GTS PMA/FEC Direct PHY IP using the Questa* – Altera® FPGA Edition simulator?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 25.1.1, you may see simulation failure with a timeout error when running 1x10.3125G RSFEC Direct Mode (System PLL Clocking) Example Design of the GTS PMA/FEC Direct PHY IP using the Questa* – Altera® FPGA Edition simulator.
This problem is limited only to 1x10.3125G RSFEC Direct Mode (System PLL Clocking). Example Design of the GTS PMA/FEC Direct PHY IP using the Questa* – Altera® FPGA Edition simulator.
Resolution
To work around this problem, modify the simulation timeout value defined in the file below.
<design_example_dir>/example_testbench/rtl/param_defines.iv
`define TIMEOUT 120000000
To:
`define TIMEOUT 150000000
The problem has been fixed starting with Quartus® Prime Pro Edition software version 25.3.
Updated 3 months ago
Version 5.0No CommentsBe the first to comment
