Knowledge Base Article
Why is the RS-FEC negotiated bit not getting cleared for F-tile Ethernet Hard IP with Auto-Negotiation and Link Training (AN/LT) and Dynamic Reconfiguration enabled Multi-rate designs?
Description
Due to a problem in the Quartus® Prime Pro Edition software version 25.1.1, you may see that the rs_fec_int_negotiated bit is not getting cleared (sticky) for AN/LT dynamic reconfiguration multi-rate designs.
This failure is seen when switching from RS-FEC profiles to no-FEC profiles.
Resolution
For a workaround, perform an ANLT CSR reset, which will clear the rs_fec_int_negotiated status bit.
This problem is fixed beginning with the Quartus Prime Pro Edition software version 25.3.
Updated 4 months ago
Version 4.0
