Knowledge Base Article
Why is the pin name/usage not the same between the Intel® Quartus® Prime fitter report and Pin-Out file for the Intel® Arria® 10 10AX090H4F34I3LG device?
Description
Due to a known problem in Intel® Quartus® Prime software version 16.1,the pin name/usage for Intel Arria® 10 GX with OPN of 10AX090H4F34I3LG are not the same between the Intel Quartus Prime fitter report and the device Pin-Out file. The pin name/usage available in Pin-Out file is correct.
Resolution
The issue is fixed in Intel Quartus Prime software version 17.1.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
