Knowledge Base Article
Why is the MPU clock frequency on my DE10-Nano SoC system set so low?
Description
Due to a problem in the Intel® Quartus® Prime Standard Edition Software version 17.0 and earlier, the MPU clock frequency might be incorrectly set if the default option is selected with the 5CSEBA6U2317DK device specified.
If the default option is selected on the Output clocks tab of the HPS IP parameter editor, the MPU clock rate may be set to 0.
Resolution
To work around this problem in the Intel Quartus Prime Standard Edition Software versions 17.0 and earlier:
- Open the output clocks page of the HPS IP parameter editor in the Platform Designer.
- Uncheck the "Use default MPU clock" setting.
- Manually set the MPU clock rate to 800 in the MPU Clock box.
- Re-generate the Platform Designer system.
- Re-compile the Intel Quartus Prime Software project.
- Generate a new Pre-loader using BSP-Editor.
This problem is fixed in the Intel Quartus Prime Standard Edition Software v17.1.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
