Knowledge Base Article
Why is the latency of my DSP block incorrect?
Description
Due to a problem in the Quartus® II software version 13.0 SP1, you may see this problem if you synthesize your design using a 3rd party synthesis tool and use the DSP input registers.
Resolution
To work around this problem, download and install patch 1.dp5n from the links below. You must install the Quartus II software version 13.0 SP1 before installing this patch.
This problem is scheduled to be fixed in a future release of the Quartus II software.
Updated 4 months ago
Version 4.0
