Knowledge Base Article
Why is the ip_type property set to "other" instead of "sdi" when using SDI protocol with Dynamically reconfigurable mode in the GTS PMA/FEC Direct PHY IP?
Description
Due to a problem in the Quartus® Prime Pro Edition software version 25.3, when configuring GTS PMA/FEC Direct PHY IP in Dynamically reconfigurable mode with SDI protocol selected, the generated QIP file sets the ip_type property to "other" instead of "sdi". This behavior was previously updated for dual simplex mode, but not for Dynamically reconfigurable mode.
Resolution
A patch is available to fix this problem for the Quartus® Prime Pro Edition software version 25.3.  Download and install the following patch to fix this problem in the Quartus® Prime Pro Edition Software version 25.3.
Or to work around this problem, you can manually edit the Direct PHY QIP file.
Locate the line:
  • set_global_assignment -name QHIP_IP_PROPERTY {{ "ip_type" : "other", "ip_direction" : "tx", "fec_used" : "false", "dr_supported" : "true", "mpip" : "true" }}
Change ip_type from "other" to "sdi":
  • set_global_assignment -name QHIP_IP_PROPERTY {{ "ip_type" : "sdi", "ip_direction" : "tx", "fec_used" : "false", "dr_supported" : "true", "mpip" : "true" }}
This problem is scheduled to be fixed in a future release of the Quartus® Prime Pro Edition software.
Updated 9 months ago
Version 4.0
