Knowledge Base Article
Why is the HyperRetimer performance worse in the Quartus II software version 15.0 than in version 14.1?
Description
In the Quartus® II software version 15.0 and later, the Hyper-Retimer is prevented from optimizing design performance due to overly conservative hold timing parameters on Hyper-Registers.
Resolution
To update the timing model for the Stratix® 10 Early Access device, download and install patch 1.01 from the links below. You must install the Quartus II software version 15.0 Update 1 before installing this patch.
- Download the version 15.0 Update 1 patch 1.01 for Windows (.exe)
- Download the version 15.0 Update 1 patch 1.01 for Linux (.run)
- Download the Readme for the Quartus II software version 15.0 Update 1 patch 1.01 (.txt)
The timing model has been updated beginning with the Quartus II software version 15.0 Update 2.
Updated 4 months ago
Version 4.0No CommentsBe the first to comment
