Knowledge Base Article
Why is the HPS booting process on Agilex™ 7 SoC FPGA devices stuck between the First Stage Bootloader and the ATF check?
Description
Due to a problem in device firmware from Quartus® Prime Pro Edition Software version 24.3.1 and earlier, you may see the HPS boot process stuck due to read/write failure on certain RAM sections on some of the Agilex™ 7 FPGA devices.
Impacted HPS RAM is the L2 cache.
Resolution
This problem is fixed by updating the device firmware to Quartus® Prime Pro Edition Software version 25.1 or Quartus® Prime Pro Edition Software version 24.3.1 and version 24.2 applied with the patch listed below.
For Quartus® Prime Pro Edition Software version 24.3.1:
Download patch 1.01fw for Windows (quartus-24.3.1-1.01fw-windows.exe)
Download patch 1.01fw for Linux (quartus-24.3.1-1.01fw-linux.run)
Download the Readme for patch 1.01fw (quartus-24.3.1-1.01fw-readme.txt)
For Quartus® Prime Pro Edition Software version 24.2:
Download patch 0.54fw for Windows (quartus-24.2-0.54fw-windows.exe)
Download patch 0.54fw for Linux (quartus-24.2-0.54fw-linux.run)
Download the Readme for patch 0.54fw (quartus-24.2-0.54fw-readme.txt)
Note:
  • Patches must be applied to the Quartus® Prime Pro Edition Software and the Quartus® Prime Pro Edition Software Programmer and Tools.
  • Recompilation is not required.
  • All programming files should be recreated.
    • Re-run the programming file generation or conversion using the Quartus® Prime Software programming file generator.
Updated 8 months ago
Version 3.0
