Knowledge Base Article
Why is the GTS transceiver reset indicator stuck when the GTS transceiver reset signal is asserted while the GTS transceiver reset indicator signal is high in the Agilex™ 5 ?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 24.1, you may see GTS transceiver reset indicator (o_tx_reset_ack / o_rx_reset_ack) is stuck when GTS transceiver reset signal (i_tx_reset / i_rx_reset) is asserted while GTS transceiver reset indicator signal is high in the Agilex™ 5.
Resolution
To work around this problem, do not assert the GTS transceiver reset signal (i_tx_reset / i_rx_reset) while the GTS transceiver reset indicator signal is high in the Agilex™ 5.
This problem is scheduled to be fixed in a future release of the Quartus Prime Pro Edition Software.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
