Knowledge Base Article
Why is the generated clock is not correct when there are multiple Intel® P-Tile Avalon® streaming for PCI Express instances?
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition Software version 20.3, PCIe clocks might not be generated correctly when there are multiple Intel P-Tile Avalon® streaming for PCI Express instances with different configurations. This problem occurs in designs targeting Intel Agilex® devices (P-Tile). The IP-generated SDC file includes wildcards for matching the clock path, this results in only the first PCIe IP's SDC file being read correctly.
Resolution
To work around the problem, use the attached SDC file to replace the one generated in <IP instance>/intel_pcie_ptile_ast_310/synth/intel_ptile_pcie.sdc.
The problem is fixed in the Intel® Quartus® Prime Pro Edition Software version 20.4.
Updated 4 months ago
Version 5.0No CommentsBe the first to comment
