Knowledge Base Article
Why is the F-Tile Ethernet FPGA Hard IP unable to achieve 100% throughput in 400GE-8, 200GE-4 or 50GE-1 variants?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 23.1, the F-Tile Ethernet FPGA Hard IP 400GE-8, 200GE-4 or 50GE-1 variants can fail to achieve 100% transmit throughput. This problem can occur when the IP has both the Client Interface parameter set to Mac Segmented and the Enable Tx Packing parameter set to Yes.
Resolution
There is no workaround for this problem.
This problem is scheduled to be fixed in version 24.2 of the Quartus® Prime Pro Edition Software.
Updated 20 days ago
Version 2.0
