Knowledge Base Article
Why is the derived tx_bonding_clocks[0] frequency of Arria®10 PCIe Hard IP Gen3 wrong?
Description
Due to a problem with Intel® Quartus® Prime Software 16.1, the generated clock tx_bonding_clocks[0] of Arria 10 PCIe Hard IP Gen3 design is wrong.
The reason is that the altera_pcie_express.sdc has some missing constraints.
Resolution
To work around this problem, please add the following sdc commands to the end of altera_pcie_express.sdc.
proc skp_sdc_puts {msg {channelId stdout}} {
 puts $channelId "altera_pcie_a10_skp.sdc >> $msg"
proc parent_of_clock {clock_name {MAX_ATTEMPTS 100}} {
   skp_sdc_puts "***********************************************************************************************"
   skp_sdc_puts "************************ Searching for the hierarchy of $clock_name ***************************"
   set attempts 0
   set parent {}
   while { $attempts < $MAX_ATTEMPTS } {
    skp_sdc_puts "Searching for clocks that match \"$parent$clock_name\"..."
      set matched_clock_collection [get_clocks -nowarn $parent$clock_name]                   ;# Try this wildcard.
    set num_matched_clocks [get_collection_size $matched_clock_collection]
    if { $num_matched_clocks == 1 } {                               ;# This is the hierarchy we are looking for.
     # Find out the full name of the parent.
     set parent [join [lrange [split [query_collection $matched_clock_collection] {|}] 0 {end-1}] {|}]
         skp_sdc_puts "Parent found : $parent"
         skp_sdc_puts "************************** Finish searching with result : $parent *****************************"
         return $parent
    } elseif { $num_matched_clocks > 1 } {       ;# Multiple clocks with the same name - this should not happen.
     skp_sdc_puts "Error: Multiple clocks match $parent$clock_name !" {stderr}
     skp_sdc_puts "Error: Matched clocks are:" {stderr}
     skp_sdc_puts "Error: [query_collection $matched_clock_collection -report_format]" {stderr}
         skp_sdc_puts "******************************* Finish searching with error ***********************************"
         return
    } else {        ;# Go up one level of hierarchy.
     append parent {*|}
     incr attempts
   skp_sdc_puts "Error: Unable to find the parent of $clock_name in $MAX_ATTEMPTS attempts!"
   return
derive_pll_clocks -create_base_clocks     ;# derive_pll_clocks needs to be called before calling parent_of_clock
derive_clock_uncertainty                  ;# in order to generate proper hierarchy.
set prefix [parent_of_clock {tx_serial_clk}]
for {set i 0} {$i != 8} {incr i} {
   create_generated_clock -divide_by 1 \
      -source     "$prefix|altpcie_a10_hip_pipen1b|g_xcvr.altpcie_a10_hip_pllnphy|g_xcvr.g_phy_g3x8.phy_g3x8|phy_g3x8|g_xcvr_native_insts[$i].twentynm_xcvr_native_inst|twentynm_xcvr_native_inst|inst_twentynm_pcs|gen_twentynm_hssi_8g_rx_pcs.inst_twentynm_hssi_8g_rx_pcs|byte_deserializer_pcs_clk_div_by_2_txclk_reg" \
      -name       "$prefix|rx_pcs_clk_div_by_4[$i]" \
                  "$prefix|altpcie_a10_hip_pipen1b|g_xcvr.altpcie_a10_hip_pllnphy|g_xcvr.g_phy_g3x8.phy_g3x8|phy_g3x8|g_xcvr_native_insts[$i].twentynm_xcvr_native_inst|twentynm_xcvr_native_inst|inst_twentynm_pcs|gen_twentynm_hssi_8g_rx_pcs.inst_twentynm_hssi_8g_rx_pcs|sta_rx_clk2_by2_1" ;# target
   create_generated_clock -multiply_by 1 -divide_by 1 \
      -source     "$prefix|altpcie_a10_hip_pipen1b|g_xcvr.altpcie_a10_hip_pllnphy|g_xcvr.g_phy_g3x8.phy_g3x8|phy_g3x8|g_xcvr_native_insts[$i].twentynm_xcvr_native_inst|twentynm_xcvr_native_inst|inst_twentynm_pcs|gen_twentynm_hssi_8g_tx_pcs.inst_twentynm_hssi_8g_tx_pcs|byte_serializer_pcs_clk_div_by_2_reg" \
      -name       "$prefix|tx_pcs_clk_div_by_4[$i]" \
                  "$prefix|altpcie_a10_hip_pipen1b|g_xcvr.altpcie_a10_hip_pllnphy|g_xcvr.g_phy_g3x8.phy_g3x8|phy_g3x8|g_xcvr_native_insts[$i].twentynm_xcvr_native_inst|twentynm_xcvr_native_inst|inst_twentynm_pcs|gen_twentynm_hssi_8g_tx_pcs.inst_twentynm_hssi_8g_tx_pcs|sta_tx_clk2_by2_1" ;# target
remove_clock      "$prefix|tx_bonding_clocks[0]"
create_generated_clock -multiply_by 1 -divide_by 10 \
   -source        "$prefix|altpcie_a10_hip_pipen1b|g_xcvr.altpcie_a10_hip_pllnphy|g_pll.g_pll_g3n.lcpll_g3xn|lcpll_g3xn|a10_xcvr_atx_pll_inst|twentynm_hssi_pma_cgb_master_inst|clk_fpll_b" \
   -master_clock  "$prefix|tx_serial_clk" \
   -name          "$prefix|tx_bonding_clocks[0]" \
                  "$prefix|altpcie_a10_hip_pipen1b|g_xcvr.altpcie_a10_hip_pllnphy|g_pll.g_pll_g3n.lcpll_g3xn|lcpll_g3xn|a10_xcvr_atx_pll_inst|twentynm_hssi_pma_cgb_master_inst|cpulse_out_bus[0]"
set_multicycle_path -setup -through [get_pins -compatibility_mode {*pld_rx_data*}] 0
set rx_clkouts [list]
 remove_clock      "$prefix|g_xcvr_native_insts[$i]|rx_clk"
 remove_clock      "$prefix|g_xcvr_native_insts[$i]|rx_clkout"
 create_generated_clock -multiply_by 1 \
      -source        "$prefix|altpcie_a10_hip_pipen1b|g_xcvr.altpcie_a10_hip_pllnphy|g_xcvr.g_phy_g3x8.phy_g3x8|phy_g3x8|g_xcvr_native_insts[$i].twentynm_xcvr_native_inst|twentynm_xcvr_native_inst|inst_twentynm_pcs|gen_twentynm_hssi_8g_rx_pcs.inst_twentynm_hssi_8g_rx_pcs|byte_deserializer_pcs_clk_div_by_4_txclk_reg" \
      -master_clock  "$prefix|tx_bonding_clocks[0]" \
      -name          "$prefix|g_xcvr_native_insts[$i]|rx_clk" \
                     "$prefix|altpcie_a10_hip_pipen1b|g_xcvr.altpcie_a10_hip_pllnphy|g_xcvr.g_phy_g3x8.phy_g3x8|phy_g3x8|g_xcvr_native_insts[$i].twentynm_xcvr_native_inst|twentynm_xcvr_native_inst|inst_twentynm_pcs|gen_twentynm_hssi_8g_rx_pcs.inst_twentynm_hssi_8g_rx_pcs|sta_rx_clk2_by4_1" ;# target
      -source        "$prefix|altpcie_a10_hip_pipen1b|g_xcvr.altpcie_a10_hip_pllnphy|g_xcvr.g_phy_g3x8.phy_g3x8|phy_g3x8|g_xcvr_native_insts[$i].twentynm_xcvr_native_inst|twentynm_xcvr_native_inst|inst_twentynm_pcs|gen_twentynm_hssi_8g_rx_pcs.inst_twentynm_hssi_8g_rx_pcs|byte_deserializer_pld_clk_div_by_4_txclk_reg" \
      -name          "$prefix|g_xcvr_native_insts[$i]|rx_clkout" \
                     "$prefix|altpcie_a10_hip_pipen1b|g_xcvr.altpcie_a10_hip_pllnphy|g_xcvr.g_phy_g3x8.phy_g3x8|phy_g3x8|g_xcvr_native_insts[$i].twentynm_xcvr_native_inst|twentynm_xcvr_native_inst|inst_twentynm_pcs|gen_twentynm_hssi_8g_rx_pcs.inst_twentynm_hssi_8g_rx_pcs|sta_rx_clk2_by4_1_out"
 set_clock_groups -exclusive \
      -group "$prefix|tx_bonding_clocks[0]" \
      -group "$prefix|g_xcvr_native_insts[$i]|rx_clkout"
      -group "$prefix|rx_pcs_clk_div_by_4[$i]"
This issue is fixed starting with the Intel® Quartus® Prime Standard Edition Software version 17.1.
Updated 3 months ago
Version 2.0
