Knowledge Base Article
Why is the “o_rx_pause” width as double as the expected value for 40GE designs when using the F-Tile Ethernet FPGA Hard IP and F-Tile Ethernet Multirate FPGA IP?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 23.4 and onward, you may see the “o_rx_pause” width as double the expected value for 40GE designs when using the F-Tile Ethernet FPGA Hard IP and F-Tile Ethernet Multirate FPGA IP.
This is due to the quanta value shifted by one extra bit.
Resolution
To work around this problem, follow the steps below.
- ) Change directory to “../[your design directory]/synth” directory.
- ) Open the file “eth_f_pause.sv” for the F-Tile Ethernet FPGA Hard IP and “eth_f_dr_tx_pause.sv” for the F-Tile Ethernet Multirate FPGA IP.
- ) Modify the file as listed below:
[Original] :
assign quanta_value =(EHIP_RATE == 0) ? (quanta_sync << 3) : (EHIP_RATE == 1) ? (quanta_sync << 3) : (EHIP_RATE == 2) ? (quanta_sync << 2) : (EHIP_RATE == 3) ? (quanta_sync << 2) : (EHIP_RATE == 4) ? (quanta_sync << 1) : {4'b000,quanta_sync} ;
[Modified] :
assign quanta_value =(EHIP_RATE == 0) ? (quanta_sync << 3) : (EHIP_RATE == 1) ? (quanta_sync << 3) : (EHIP_RATE == 2) ? (quanta_sync << 1) : (EHIP_RATE == 3) ? (quanta_sync << 2) : (EHIP_RATE == 4) ? (quanta_sync << 1) : {4'b000,quanta_sync} ;
This problem is fixed beginning with the Quartus® Prime Pro Edition software version 24.3.1.
