Knowledge Base Article
Why is my programming file not updated when I use Update Memory Initialization flow?
Description
Due to a problem in the Quartus® II software versions 12.0 SP2 and earlier, the Update Memory Initialization (quartus_cdb --update_mif) flow does not work for designs targeting Cyclone® V and Arria® V devices. Due to this problem, no error is generated, but the programming file is not updated.
Resolution
This problem is fixed beginning with the Quartus II software version 12.1
Updated 11 months ago
Version 3.0
