Knowledge Base Article
Why is an SEU error reported in Agilex™ 7 devices with Intel® Enpirion® Power Module ED8401 and Quartus® Prime Pro Edition Software versions 21.3 and 21.4?
Description
When using Intel® Enpirion® Power Modules, you may see an SEU error reported when using Agilex™ 7 devices and Quartus® Prime Pro Edition Software versions 21.3 and 21.4.
This SEU error is reported because the voltage required by Agilex™ 7 devices is higher than the default Over-Voltage (OV) warning setting in the Intel® Enpirion® Power Module ED8401.
The OV warning is recorded by Agilex™ 7 devices as an SEU error.
You may see the SEU error, as shown in the screenshot below if you use the Configuration Debugger Tool (refer to AN 955: Programmer’s Configuration Debugger Tool).
Resolution
To fix this problem, set the VOUT_OV_WARN_LIMIT of ED8401 to be 950mV.
In general, refer to Agilex™ 7 Power Management User Guide, chapter "Fault Management and Error Reporting," to properly set all the relevant parameters in the voltage regulator.
