Knowledge Base Article
Why is Agilex® 5 FPGA HPS IP's Auto-Place IP failed to place the selected peripheral after Apply Selections ?
Description
When assigning peripherals to the HPS IO, you may encounter a placement limitation due to the peripheral cannot fit into the available unused IO locations. The error message is not displayed in the Parameterization Messages but appears in the Messages window after running Auto-Place IP.
This snapshot is an example:
Resolution
This problem is plan to be fix in Quartus® Prime Pro Edition Software v26.1.
Updated 4 months ago
Version 4.0
