Knowledge Base Article
Why has my VCCL_HPS and VCCIO_HPS power estimates increased in the Quartus® Prime Pro Edition Software v26.1?
Description
Starting in the Quartus® Prime Pro Edition Software version 26.1, the Max Power methodology for the HPS CPU subsystem in Agilex® 3 and Agilex® 5 FPGA devices was updated to account for sustained CPU execution. As a result, the power model changed and there is an increase in power estimation for the following power rails when compared to the version 25.3.1 or earlier:
  1. VCCL_HPS_CORE0_CORE1, VCCL_HPS_CORE2, and VCCL_HPS_CORE3: up to 514 mW per rail, depending on HPS core utilization and operating frequency, when CPU Application = Max Power
  2. VCCIO_HPS: approximately 2 mW
Resolution
Perform either of the following options :-
  • Migrate your existing design to the Quartus® Prime Pro Edition Software version 26.1 or later for more accurate power estimation of VCCL_HPS (CORE0_CORE1, CORE2, and CORE3) and VCCIO_HPS
  • Manually import existing PTC, PTA, QPTC, or QPTA files generated in version 25.3.1 or earlier into the Quartus® Prime Pro Edition Software version 26.1 Power & Thermal Analyzer and check the updated power estimates.
Updated 7 months ago
Version 2.0
