Knowledge Base Article
Why ECC protection does not work in F-Tile Dynamic Reconfiguration Suite IP?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 26.1 and earlier, you will observe the Enable ECC protection parameter in the F-Tile Dynamic Reconfiguration Suite IP does not function as expected. Even though you set Enable ECC protection parameter as ON, the ECC protection could not be enabled.
Resolution
There is no workaround available.
This problem is scheduled to be fixed in a future release of the Quartus Prime Pro Edition software.
Updated 7 months ago
Version 2.0
