Knowledge Base Article
Why doesn't the IOPLL dynamic phase shift feature work on Arria® 10 FPGA and Cyclone® 10 GX FPGA devices?
Description
You may see that the IOPLL dynamic phase shift feature does not work as expected in Arria® 10 FPGA and Cyclone® 10 GX FPGA devices when both “access to dynamic phase shift ports” and “dynamic reconfiguration of PLL” options are enabled in the IOPLL FPGA IP.
This is because the IOPLL FPGA IP does not simultaneously support the dynamic reconfiguration and the direct phase shift feature.
Resolution
The problem has been fixed starting with Quartus® Prime Pro Edition software version 24.2.
Updated 4 months ago
Version 6.0No CommentsBe the first to comment
