Knowledge Base Article
Why doesn't the CDR freeze feature work for F-Tile PMA/FEC Direct PHY IP?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 23.3 and earlier, the CDR freeze feature for the GPON application does not function as expected when using F-Tile PMA/FEC Direct PHY IP.
Resolution
To get the CDR freeze feature to work, you need to:
1. Configure the F-Tile PMA/FEC Direct PHY Intel® FPGA IP GUI as follows:
  • Set FGT PMA configuration rules as GPON
  • Set the Adaptation mode to manual
  • Enable fgt_rx_cdr_fast_freeze_sel port
  • Enable fgt_rx_cdr_freeze port
2. After the design SOF file is programmed, enable the CDR freeze feature by setting the following two FGT registers:
  • 0x62000[16] to 1'b1
  • 0x62004[12] to 1'b1
        Note that the above registers only apply to channels placed on Lane 0. You need to add an offset address for channels placed on other lanes. For more details, please refer to the F-Tile Architecture and PMA and FEC Direct PHY IP User Guide.
3. Drive the signals as follows:
  • tie the fgt_rx_cdr_fast_freeze_sel signal to 1'b0
  • assert the fgt_rx_cdr_freeze signal to 1'b1 when burst ends, and de-assert the fgt_rx_cdr_freeze signal to 1'b0 when burst starts
This problem is fixed beginning with the Quartus® Prime Pro Edition Software version 24.1
Updated 11 months ago
Version 3.0
