Knowledge Base Article
Why doesn't my Quartus II XCVR_RX_LINEAR_EQUALIZER_CONTROL QSF assignment have any effect on the Stratix V GX equalizer in Quartus II software versions 12.1 and 12.1sp1.
Description
Due to a bug in Quartus® II software versions 12.1 and 12.1sp1, the XCVR_RX_LINEAR_EQUALIZER_CONTROL QSF assignment may not have an effect on the Stratix® V GX equalizer.
Resolution
To work around this issue you should write the equalization value through the Avalon® Memory Mapped interface.
Alternatively you can install the following appropriate patch.
Quartus II software version 12.1
Quartus II software version 12.1 SP1 dp6
This issue will be fixed in a future version of the Quartus II software.
Updated 4 months ago
Version 4.0
