Knowledge Base Article
Why doesn't my Intel® Arria® 10 SoC boot using FPGA boot mode when all dedicated I/O are unused?
Description
Due to a problem in Intel® Quartus® Prime Pro/Standard Software, OSC_CLK_1_HPS, nPOR_RST and nRST_HPS input ports are disabled by U-boot settings.
Resolution
1)    Move to the hps_isw_handoff folder in your design.
2)    Open hps.xml
3)    Find the following section.
<csr>
    <!-- Unused pin 1 -->
    <config name='i_io48_pin_mux_dedicated_io_grp.configuration_dedicated_io_1.rtrim'        value='1' />
    <config name='i_io48_pin_mux_dedicated_io_grp.configuration_dedicated_io_1.input_buf_en' value='0' />
    <config name='i_io48_pin_mux_dedicated_io_grp.configuration_dedicated_io_1.wk_pu_en'     value='1' />
    <config name='i_io48_pin_mux_dedicated_io_grp.configuration_dedicated_io_1.pu_slw_rt'    value='0' />
    <config name='i_io48_pin_mux_dedicated_io_grp.configuration_dedicated_io_1.pd_slw_rt'    value='0' />
    <config name='i_io48_pin_mux_dedicated_io_grp.configuration_dedicated_io_1.pu_drv_strg'  value='0' />
    <config name='i_io48_pin_mux_dedicated_io_grp.configuration_dedicated_io_1.pd_drv_strg'  value='0' />
    <!-- Unused pin 2 -->
    <config name='i_io48_pin_mux_dedicated_io_grp.configuration_dedicated_io_2.rtrim'        value='1' />
    <config name='i_io48_pin_mux_dedicated_io_grp.configuration_dedicated_io_2.input_buf_en' value='0' />
    <config name='i_io48_pin_mux_dedicated_io_grp.configuration_dedicated_io_2.wk_pu_en'     value='1' />
    <config name='i_io48_pin_mux_dedicated_io_grp.configuration_dedicated_io_2.pu_slw_rt'    value='0' />
    <config name='i_io48_pin_mux_dedicated_io_grp.configuration_dedicated_io_2.pd_slw_rt'    value='0' />
    <config name='i_io48_pin_mux_dedicated_io_grp.configuration_dedicated_io_2.pu_drv_strg'  value='0' />
    <config name='i_io48_pin_mux_dedicated_io_grp.configuration_dedicated_io_2.pd_drv_strg'  value='0' />
    <!-- Unused pin 3 -->
    <config name='i_io48_pin_mux_dedicated_io_grp.configuration_dedicated_io_3.rtrim'        value='1' />
    <config name='i_io48_pin_mux_dedicated_io_grp.configuration_dedicated_io_3.input_buf_en' value='0' />
    <config name='i_io48_pin_mux_dedicated_io_grp.configuration_dedicated_io_3.wk_pu_en'     value='1' />
    <config name='i_io48_pin_mux_dedicated_io_grp.configuration_dedicated_io_3.pu_slw_rt'    value='0' />
    <config name='i_io48_pin_mux_dedicated_io_grp.configuration_dedicated_io_3.pd_slw_rt'    value='0' />
    <config name='i_io48_pin_mux_dedicated_io_grp.configuration_dedicated_io_3.pu_drv_strg'  value='0' />
    <config name='i_io48_pin_mux_dedicated_io_grp.configuration_dedicated_io_3.pd_drv_strg'  value='0' />
4)    Replace above 3 unused settings with the following OSC_CLK_1_HPS, nPOR_HPS and nRST_HPS settings, and save hps.xml.
<csr>
    <!-- OSC_CLK_1_HPS -->
    <config name='i_io48_pin_mux_dedicated_io_grp.configuration_dedicated_io_1.input_buf_en' value='1' />
    <config name='i_io48_pin_mux_dedicated_io_grp.configuration_dedicated_io_1.pu_drv_strg'  value='8' />
    <config name='i_io48_pin_mux_dedicated_io_grp.configuration_dedicated_io_1.pd_drv_strg'  value='10' />
    <!-- nPOR_HPS -->
    <config name='i_io48_pin_mux_dedicated_io_grp.configuration_dedicated_io_2.input_buf_en' value='1' />
    <config name='i_io48_pin_mux_dedicated_io_grp.configuration_dedicated_io_2.pu_drv_strg'  value='8' />
    <config name='i_io48_pin_mux_dedicated_io_grp.configuration_dedicated_io_2.pd_drv_strg'  value='10' />
    <!-- nRST_HPS -->
    <config name='i_io48_pin_mux_dedicated_io_grp.configuration_dedicated_io_3.input_buf_en' value='1' />
    <config name='i_io48_pin_mux_dedicated_io_grp.configuration_dedicated_io_3.pu_drv_strg'  value='8' />
    <config name='i_io48_pin_mux_dedicated_io_grp.configuration_dedicated_io_3.pd_drv_strg'  value='10' />
5)    Create one uboot project and make the bin file based on new handoff file
Updated 11 months ago
Version 3.0
