Knowledge Base Article
Why does the TimeQuest timing analyzer not report setup and hold timing for the signal phasestep for Stratix III and Stratix IV designs using PLL reconfiguration?
Description
For Stratix® III and Stratix IV designs using PLL reconfiguration, the TimeQuest timing analyzer does not report setup or hold values for the signal phasestep because the timing for this signal is not critical.
The Stratix III Device Handbook chapter Clock Networks and PLLs in Stratix III Devices (PDF) and the Stratix IV Device Handbook chapter Clock Networks and PLLs in Stratix IV Devices (PDF) indicate that all PLL reconfiguration signals are synchronous to scanclk, and that all signals should meet setup and hold in relation to scanclk. However, the signal phasestep should be held for multiple cycles of scanclk and deasserted only after the signal phasedone goes low. The correct usage of phasestep is also documented in Application Note 454: Implementing PLL Reconfiguration in Stratix III and Stratix IV Devices (PDF). Because the signal is used in this manner, setup and hold analysis is not required for phasestep.
Resolution
The device handbooks are scheduled to be updated to clarify the timing requirements for PLL reconfiguration signals.
Updated 11 months ago
Version 3.0
