Knowledge Base Article
Why does the Stratix® V device Transceiver Toolkit display a "Couldn't grab settings for channel" message when using Quartus® II software versions 14.1 and 14.1.1?
Description
The Transceiver Toolkit Console message pane may report the message: "Couldn't grab settings for channel" when using Quartus II software versions 14.1 and 14.1.1.
You may also see after regenerating a Transceiver Toolkit Qsys design in Quartus II software versions 14.1 and 14.1.1 that the Transceiver Toolkit Console does not pre-populate the Receiver Channels, Transmitter Channels, and Transceiver Links tabs.
Resolution
To work around this problem, you can use one of the sequences below:
- Revert your Transceiver Toolkit Qsys design to Quartus II software version 14.0
- Recompile the project in Quartus II software version 14.0, 14.1, or 14.1.1
- Open the Transceiver Toolkit GUI from Quartus II software versions 14.1 or 14.1.1
Or
- Download and apply the following patch to Quartus II software version 14.1.1
- Regenerate your Qsys design and recompile your project.
Note: The Data Rate and PLL refclk frequency fields will not be reported in the Transceiver Toolkit Console, but the design will work
This problem is fixed in Intel® Quartus® Prime Pro Edition Software version 15.1.
Updated 4 months ago
Version 5.0No CommentsBe the first to comment
