Knowledge Base Article
Why does the Stratix® 10 FPGA SmartVID device fail to configure in PMBus Master Mode when using Quartus® Prime Pro Edition Software firmware version 21.3?
Description
Due to a problem when using Quartus® Prime Pro Edition Software versions 21.1, 21.2, and 21.3 and Stratix® 10 FPGA SmartVID devices with a VID fuse value of 900mV, there is a missing VOUT_COMMAND in PMBus Master Mode. This causes the external voltage regulator to not be configured to the expected voltage level resulting in configuration failure.
Resolution
To work around this problem, use the patch for Quartus® Prime Pro Edition Software version 21.3 below.
For earlier versions of Quartus® Prime Pro Edition Software, contact Altera.
This problem is fixed starting from Quartus® Prime Pro Edition Software version 21.4.
Updated 8 months ago
Version 4.0No CommentsBe the first to comment
