Knowledge Base Article
Why does the simulation of the GTS Ethernet FPGA Hard IP for the Agilex™ 5 FPGA E-Series Device (Group A), when using System PLL in custom mode, fail with the Quartus® Prime Pro Edition Software version 24.2?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 24.2, the simulation of the GTS Ethernet FPGA Hard IP for the Agilex™ 5 FPGA E-Series Device (Group A) when using System PLL in custom mode fails under the conditions below.
  • Using System PLL in custom mode
  • Reference clock frequency of the GTS Ethernet FPGA Hard IP is 322.265625 MHz
  • Output clock frequency of the GTS Ethernet FPGA Hard IP is configured to 937.5 MHz
Resolution
This problem is fixed beginning with the Quartus® Prime Pro Edition software version 24.3.
Updated 3 months ago
Version 2.0
