Knowledge Base Article
Why does the report.html can not display on the Intel® Programmable Acceleration Card with Arria® 10 GX FPGA?
Description
If you compile OpenCL™ example design, the report.html may not be displayed on the CentOS 7.4/Kernel 3.10 server as follow:
Even if you move the .html file to your local computer, it also can not display as follow:
Resolution
To work around this problem, you should copy the entire report folder from the server to the local computer, the html file can be display normally as follow:
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
