Knowledge Base Article
Why does the R-Tile IP for Compute Express Link* (CXL*) Type3 Design Example report a UVM_FATAL message when running simulation?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 23.1, you might observe the following error message when simulating the R-Tile IP for Compute Express Link* (CXL*) Type3 Design Example:
Resolution
To work around this problem, update to a newer version of Avery BFM and install a patch for the Intel® Quartus® Prime Pro Edition Software version 23.1.
- Update Avery BFM version to apciexactor-2.5b.cxl;
- Download and install patch 0.08 from the files below.
This problem is fixed beginning with the Quartus® Prime Pro Edition software version 23.2.
Updated 4 months ago
Version 6.0No CommentsBe the first to comment
