Knowledge Base Article
Why does the Quartus® Prime Programmer GUI fail JIC programming with "Different TAPS selected" or "Operation failed" in AS mode for device AGIB027R31B1E1VAA?
Description
In Quartus® Prime Software versions 24.2 and 25.1, the Quartus Programmer GUI may fail during JIC programming when the board is in Active Serial (AS) boot mode.
This issue is specific to the Agilex® 7 SoC device with OPN AGIB027R31B1E1VAA paired with QSPI flash MT25QU01GBBB8E12-0SIT. The GUI reports "Different TAPS selected." or "Operation failed" when the flash already contains existing data.
The same JIC programs successfully on the same board using the quartus_pgm command-line tool.
Note: This issue does not affect all Agilex®7 FPGA OPNs - it has been reproduced only on AGIB027R31B1E1VAA.
Resolution
This issue is specific to OPN AGIB027R31B1E1VAA on Quartus Prime versions 24.2 and 25.1.
To resolve or work around this issue:
- Upgrade to Quartus® Prime Software version 25.1.1 or later, where this issue is resolved for AGIB027R31B1E1VAA.
- Alternatively, use the quartus_pgm command-line utility to program the JIC file instead of the GUI Programmer on affected versions (24.2 and 25.1).
Updated 2 months ago
