Knowledge Base Article
Why does the Passive Serial (PS) configuration fails in Intel® Cyclone® 10 LP, when using a Programmer Object File (.pof) generated with the Programming File Generator?
Description
Due to a problem in the Intel® Quartus® Prime 19.4 Pro Edition and earlier, a Programmer Object File (.pof)  generated with the Programming File Generator has wrong data format in Intel Cyclone® 10 LP.  So the Passive Serial (PS) configuration with the .pof fails.
Resolution
Use the Convert Programming Files instead of the Programming File Generator when the Intel® Quartus® Prime 19.4 Pro Edition or earlier is used.
This problem has been fixed in the Intel® Quartus® Prime 20.1 Pro Edition.
Updated 11 months ago
Version 3.0
