Knowledge Base Article
Why does the Nios® V  application project failed to build and  “cannot find -lstdc++” message was observed?
Description
Due to a missing multilib arch/abi-to-directory mappings in the xPack GNU RISC-V Embedded GCC v10.1.0-1.1 toolchain (Windows Build), the message was observed in the Intel® Quartus® Prime Pro Edition Software version 21.3 while building the application project of the Nios® V/m Processor Intel FPGA IP design in Windows after the command “make -C <Application project build directory>”.
To verify if the toolchain has the necessary mappings, please use the command below.
riscv-none-embed-gcc.exe --print-multi-lib
The expected results should contain rv32ia/ilp32;@march=rv32ia@mabi=ilp32 to build the Nios® V application project.
Resolution
To work around this problem, download and install the xPack GNU RISC-V Embedded GCC v8.3.0-2.3.
Download and install xPack GNU RISC-V Embedded GCC v8.3.0-2.3  from the appropriate link below.
Updated 3 months ago
Version 3.0
