Knowledge Base Article
Why does the Megawizard Plug-in Manager fail to launch the Triple-Speed Ethernet FPGA IP when using the Quartus® Prime Software Standard Edition v18.0?
Description
Due to an update in the Quartus® Prime Software Standard Edition v18.0 and onwards, the following error will be seen when trying to launch the Triple-Speed Ethernet FPGA IP using the Megawizard Plug-in Manager:
"Failed to launch Megawizard Plug-in Manager. Triple-Speed Ethernet FPGA IP v18.0 could not be found in the specified library paths".
Resolution
To work around this problem, launch the Triple-Speed Ethernet FPGA IP using IP Catalog.
This problem is scheduled to be fixed in a future release of the Quartus® Prime Software Standard Edition.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
