Knowledge Base Article
Why does the Mailbox Client Intel® FPGA IP not function correctly when connected to an asynchronous reset?
Description
In Intel® Quartus® Prime Pro Edition software versions 19.4 and earlier, you may find that the Mailbox Client Intel FPGA IP does not function correctly when connected to an asynchronous reset including the output of the Reset Release Intel® FPGA IP when using Intel® Stratix® 10 devices.
Resolution
To work around this, a reset synchronizer should be used with the Mailbox Client Intel FPGA IP . This can be implemented using the Reset Bridge IP available in Platform Designer. This problem is fixed starting with Intel Quartus Prime Pro Edition software version 20.1.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
