Knowledge Base Article
Why does the Intel Agilex® 7 F-Tile device tx_pll_locked signal fail to assert when OSC_CLK_1 is used as the configuration clock source?
Description
Due to a problem in the Intel® Quartus® Programmer version 23.3, the Intel Agilex® 7 F-Tile device tx_pll_locked signal fails to assert when the OSC_CLK_1 is used as the configuration clock source.
Resolution
To work around this problem in the Intel® Quartus® Prime Pro Edition Software version 23.3, install the following patch:
- Intel® Quartus® Prime Pro Edition Software v23.3 Patch 0.22fw for Windows (.exe)
- Intel® Quartus® Prime Pro Edition Software v23.3 Patch 0.22fw for Linux (.run)
- Readme for Intel® Quartus® Prime Pro Edition Software v23.3 Patch 0.22fw (.txt)
This problem is fixed in the Intel® Quartus® Prime Pro Edition Software version 23.4.
Updated 20 hours ago
Version 4.0No CommentsBe the first to comment
