Knowledge Base Article
Why does the Intel® Quartus® Prime Pro Edition software generate timing violations when using the Intel® Stratix® 10 L- and H-Tile Transceiver PHY IP in bonding mode?
Description
When using the Intel® Stratix® 10 L- and H-Tile Transceiver PHY IP in bonding mode, use the tx_coreclk from the master channel as the source clock for all of the other channels in the bonded interface. If this guideline is not met, you will see timing violations for a clock transfer from one tx_outclock domain to another.
Resolution
The information is scheduled to be updated in a future update of the Intel® Stratix® 10 L- and H-Tile Transceiver PHY User Guide.
Updated 3 months ago
Version 2.0
