Knowledge Base Article
Why does the Intel® OFS 2.1.0 compilation failure happen in the Intel® Quartus® Prime Software v21.3 GUI?
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition Software v21.3, you might see compilation failure on the Intel® Open FPGA Stack (Intel® OFS) 2.1.0 version with compilation flow in GUI.
In GUI compilation, the path with global environment cannot be recognized while executing the post_module_hook.tcl file.
Error: Tcl Script File $: not found
Evaluation of Tcl script $: unsuccessful
Resolution
In script compilation, it can be recognized and executed successfully:
quartus_sh -t $::env(BUILD_ROOT_REL)/syn/ofs_ac/common/setup/post_module_hook.tcl quartus_asm ofs_top ofs_top
You can use script compilation or remove assignment in ofs_top.qsf as a workaround:
set_global_assignment -name POST_MODULE_SCRIPT_FILE "quartus_sh:$::env(BUILD_ROOT_REL)/syn/ofs_ac/common/setup/post_module_hook.tcl"
This problem is fixed beginning with the Intel® Quartus® Prime Pro Edition Software v21.4.
Updated 11 months ago
Version 3.0
