Knowledge Base Article
Why does the Intel® L-/H-Tile Avalon® Streaming IP for PCI Express* report timing violations on clock domain crossing paths?
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition Software version 20.3 to 21.2, you may see timing violations between paths that are crossing clock domains in the Intel® L-/H-Tile Avalon® Streaming IP for PCI Express*.
The Intel® L-/H-Tile Avalon® Streaming IP for PCI Express* generates the required synchronization logic for the clock domain crossing, however, the Synopsys* Design Constraints Files (.sdc) does not correctly constrain these paths.
Resolution
To work around this problem, follow the next steps:
- Download altera_pcie_s10_gen3x16_cdc Synopsys* Design Constraints file (.sdc)
- Add altera_pcie_s10_gen3x16_cdc.sdc to your Intel® Quartus® project
- altera_pcie_s10_gen3x16_cdc.sdc should be placed after the Intel® L-/H-Tile Avalon® Streaming IP for PCI Express* configuration file (.ip)
This problem is fixed starting with the Intel® Quartus® Prime Pro Edition Software version 21.3.
Updated 4 months ago
Version 4.0No CommentsBe the first to comment
