Knowledge Base Article
Why does the Intel® Arria® 10 Hard IP for PCI* Express signal tx_out periodically transition to high impedance in simulation at LTSSM = Recovery Speed state?
Description
When the LTSSM is in Recovery Speed state, the Intel® Arria® 10 Hard IP for PCI* Express will send out Electrical Idle Ordered Sets (EIOS) before transitioning to electrical idle. This behavior is represented in simulation by tx_out signal periodically transitioning to high impedance.  Therefore, if a third-party Bus Functionality Model (BFM) used for simulation interprets the high impedance as unknown symbols, this will cause the bit sequence to be corrupted and LTSSM transitioning between Recovery Speed and Recovery Lock state.
Resolution
Simulations using Intel® BFM and Avery* BFM are not affected by this behavior.
If using third party BFM for simulation, please ensure tx_out transitioning to high impedance is not interpreted as unknown symbol.
Updated 3 months ago
Version 3.0
