Knowledge Base Article
Why does the Intel® Stratix® 10 H-tile Transceiver Native PHY IP show an incorrect magnitude range of pre-emphasis first pre-tap and first post-tap?
Description
Due to a problem with the Intel® Stratix® 10 H-tile Transceiver Native PHY IP in Intel® Quartus® Prime Pro Edition Software version 17.1 IR1, the magnitude range of pre-emphasis first pre-tap and first post-tap magnitude shown is incorrect.
The correct magnitude range is 0 to 15 for pre-emphasis first pre-tap and 0 to 24 for pre-emphasis first post-tap.
Resolution
This problem has been fixed in Intel® Quartus® Prime Pro Edition Software version 17.1 IR2
Updated 2 months ago
