Knowledge Base Article
Why does the Intel® Arria® 10 fPLL IP generate the wrong phase shift?
Description
Due to a problem with the Intel® Quartus® Prime Edition Software version 17.1, you may see the fPLL IP for Intel® Arria® 10 sets an incorrect phase shift. It generates double the desired phase shift.
Resolution
To work around this problem, set a phase shift to be half of what you require.
To check phase shift settings, use the TimeQuest Timing Analyzer command "derive_pll_clocks". It reports the actual hardware configuration.
Updated 1 month ago
