Knowledge Base Article
Why does the insertion loss range of the VSR_HIGH_LOSS and VSR_LOW_LOSS parameters in the F-Tile Architecture and PMA, and the FEC Direct PHY IP User Guide "3.12.2. FGT PMA Settings" change in the Quartus® Prime Pro Edition software version 24.2?
Description
VSR mode settings in the F-Tile Architecture and PMA and FEC Direct PHY IP User Guide “3.12.2 FGT PMA Settings”
[version 24.1]
VSR mode is set when insertion loss < 10dB, RX auto adaptation is ON for >= 23 Gbps NRZ or any PAM4 rate:
  • For Insertion Loss < 5 dB:
    • set_instance_assignment -name HSSI_PARAMETER "vsr_mode=VSR_MODE_LOW_LOSS" - to <RX_SERIAL_PIN> -entity <TOP_LEVEL_NAME>
  • For Insertion Loss > 5 dB but < 10 dB:
    • set_instance_assignment -name HSSI_PARAMETER "vsr_mode=VSR_MODE_HIGH_LOSS" - to <RX_SERIAL_PIN> -entity <TOP_LEVEL_NAME>
Else VSR_MODE_DISABLE is set by default by the Quartus® Prime Pro Edition software for rates below < 23 Gbps, where VSR is not required.
[version 24.2 and onward]
VSR Mode for NRZ:
  • Data Rate >= 23 Gbps and Insertion Loss <= 10 dB:
  • Others:
    • set_instance_assignment -name HSSI_PARAMETER "vsr_mode=VSR_MODE_DISABLE" -to <RX_SERIAL_PIN>  -entity <TOP_LEVEL_NAME>
Resolution
The change is not dependent on the Quartus® Prime Pro Edition software version. It is due to more validation data regarding VSR mode in NRZ and PAM4, showing a more accurate understanding of the insertion loss relationship with VSR mode.
Updated 11 months ago
Version 3.0
