Knowledge Base Article
Why does the HPS SPI Master fail when slave select is mapped to GPIO?
Description
Due to a problem with the SPI IP linux driver (spi-dw.c) in linux-socfpga kernel 4.1.22-ltsi, the SPI IP will fail to operate if slave select is routed to GPIO with the cs-gpios entry in device tree.
Resolution
This problem is fixed in the linux-socfpga-linux kernel 4.1.33-ltsi.
GIT location:
https://github.com/altera-opensource/linux-socfpga
Precompiled version on Rocketboards.org:
https://rocketboards.org/foswiki/Documentation/GSRD170ReleaseNotes
Updated 19 days ago
Version 2.0
