Knowledge Base Article
Why does the High Bandwidth Memory (HBM2E) Interface Agilex® 7 IP fail generation after disabling Reserve Channel 2 and Channel 3 for HPS boot from HBM?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 26.1.1, the High Bandwidth Memory (HBM2E) Interface Agilex® 7 IP Interface IP GUI does not correctly handle the "Reserve Channel 2 and Channel 3 for HPS boot from HBM" option when it is disabled after being enabled.
After enabling the option and subsequently unchecking it, the IP may enter an inconsistent configuration state and fail during IP generation.
Users may observe interface mismatch errors similar to the following:
Error: hbm2e.hbm_fp_0: Interface t_ch2_u0_axi4noc is not the same type as exported interface tniu_ch2_u0.target_inst_0 (should be a hps_axi4noc)
Error: hbm2e.hbm_fp_0: Interface t_ch2_u1_axi4noc is not the same type as exported interface tniu_ch2_u1.target_inst_0 (should be a hps_axi4noc)
Error: hbm2e.hbm_fp_0: Interface t_ch3_u0_axi4noc is not the same type as exported interface tniu_ch3_u0.target_inst_0 (should be a hps_axi4noc)
Error: hbm2e.hbm_fp_0: Interface t_ch3_u1_axi4noc is not the same type as exported interface tniu_ch3_u1.target_inst_0 (should be a hps_axi4noc)
Error: hbm2e.hbm_fp_0: Interface t_ch2_ch3_sb_axi4noc tried to export unknown interface tniu_ch2_ch3_sb.target_inst_0
The issue is only observed after toggling the HPS boot from HBM option from enabled to disabled.
Resolution
As a workaround, if the "Reserve Channel 2 and Channel 3 for HPS boot from HBM" option is enabled by mistake, close and restart the IP Parameter Editor GUI without saving any changes. Reopen the IP and continue the configuration with the desired setting.
This problem is scheduled to be resolved in a future release of the Quartus® Prime Pro Edition Software.
