Knowledge Base Article
Why does the H2D *ST device port of the Scalable Scatter-Gather DMA FPGA IP send non-contiguous data in the DMA PCIe mode for Completion TLPs?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 24.2, the Scalable Scatter-Gather DMA FPGA IP DMA PCIe Mode can only support incoming Completion TLPs for Mem Read Requests with payload lengths that aligned to the data width of the H2D *ST device port, except for the last Completion TLP where the TLP payload length equals to remaining byte count of the request. The AXI-ST Manager or Avalon-ST Source interface of the H2D device port may transmit non-contiguous data when the incoming Completion TLP payload length doesn’t meet this condition.
Examples of possible combinations of 400-byte Memory Read Request Completion TLP payload length with 256-bit (32 bytes) H2D ST port data width:-
Supported combinations: 256 bytes + 144 bytes, 64 bytes + 256 bytes + 80 bytes
Unsupported combinations: 208 bytes + 64 bytes + 128 bytes, 144 bytes + 256 bytes
Resolution
There is no workaround for this problem.
This problem is scheduled to be fixed in a future release of the Quartus® Prime Pro Edition Software.
